Remote Destination showing on Cisco Phone Caller ID Across Multiple Clusters?
Pengu
If a remote destination is calling in to another desk phone on the same cluster (PBX) the caller ID from the attached directory number. If you call to another cluster it will just show "WIRELESS CALLER". I am wondering if there is any solution so all clusters are able to show show up with the directory numbers caller ID?
Kaloyan
disregard
