Remove prefix form IP phone display CME
rhobab
Hello
I have a CME configured to add a prefix on the outgoing pots dial-peer. Connection to the PSTN is done via a E1.
When we dial a number and the connection is made the ip phone displays the prefix followed by number we dialed. For example we dial 123456789 and the prefix is 99999 when the call is connected the ip phone displays 99999123456789.
How can I remove the prefix from the phone's display?
10 Replies 10
islam.kamal
Level 10
Level 10
you have to solution under dial-peer pots:-
1-
dial-peer voic 10 pots
forward-dgits 9                     (this forward will calculate 9 digits and allow to go over pots , so you will transfer  123456789)
or
destination-pattern 99999.123456789                 (or add . after 99999)
Thank you
Please rate all useful information
My current configuration on the dial-peers is as follows:
dial-peer voice 290 pots
corlist incoming call-Internas
corlist outgoing call-Telemoveis
description *** MOBILE - PSTN ***
destination-pattern 09[1236].......
direct-inward-dial
port 0/1/0:15
forward-digits 9
prefix 90790
I already have the forward-digits command.
The prefix has to be sent to the PSTN operator for billing purposes.
Ok , please try the below: by add . after 09
destination-pattern 09.[1236].......
Thank you
I hope to try the below
1-
no forward-digits 9
2-
default forward-digits
without (. after prefix or no-forward digits).
Thank you
I have tried these configurations but the ip phone still displays the prefix + dialed number.
please try the below , this will fix your problem:-
voice service voip
no supplementary-service h225-notify cid-update
Thank you
I have tried that as well with no luck. This is a Call Manager Express so I'm not sure this command would do anything but I have tried it.
hi
can you put under telephony-service
secondary-dialtone 09
Thank you
Please rate all useful infromation
Have you tried to use a voice translation rule to add the prefix instead of doing it directly on the outgoing dial-peer?
voice translation-rule 40
rule 1 /^\(09[1236].......\)$/ /90790\1/
voice translation-profile PSTN-OUT
translate called 40
direct-inward-dial
port 0/1/0:15
forward-digits 9
translation-profile outgoing PSTN-OUT
no prefix
Please remember to rate helpful responses and identify helpful or correct answers.
Response Signature
he prefix is part of the dialled number. It is a routable number because your provider uses it for billing records. You cant remove it from the display because this is the connected number. Unless your provider drops the prefix when the call is connected, I dont see a way you can drop it from displaying on the phones. This is my take on this and I may be wrong.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
