removing a license from a cucm server
mikedurbin
Does anyone know how to remove a license from a cucm server?
2 Accepted Solutions
Rob Huffman
Hi Mike,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
just to add something to great info from Rob, be aware that's only for 6.1(2) and above. if you have a previous version you'll have to open a TAC case because root access is required to delete the license
java
if this helps, please rate
java
Rob Huffman
Hi Mike,
file delete
Command Syntax
file delete
Parameters
Options
Hope this helps!
Rob
java
java
Thank you gentlemen.
