03-05-2013 10:05 PM - edited 03-16-2019 04:05 PM
Cisco 7911 model is no more available in the market. Can anyone suggest an equivalent IP phone availablle in the market which works with CUCM 6.1 and above?
Thanks & Regards,
03-05-2013 10:13 PM
As per Cisco EOX link the 6921 phones whould be good for you. But minimum CUCm version required is 7.1.2
Ronak Patel
Rate all helpful post by clicking stars below the answer.
03-05-2013 10:21 PM
Right now we have CUCM 6.1 ver and planning to upgrade to ver 9.0 in 6 months of time from now. We need to procure the ip phones to serve the users for next 6 months to work with 6.1 and later move on to the new ver. What is the best option?
Thanks & Regards,
03-05-2013 10:36 PM
Closest which I could find is 7931 which is supported in CUCM 6.X also.
Ronak Patel
03-05-2013 11:08 PM
Thanks Ronak. 7931G can work with 6.0 and later version and is the closest match to 7911...
Thanks & Regards,
03-05-2013 10:37 PM
03-05-2013 11:09 PM
Thanks Venkitesh. The doc is really useful to find the right end node for our current version of CUCM...
Thanks & Regards,
