Replacement of cisco 7911
protocol_1984
Cisco 7911 model is no more available in the market. Can anyone suggest an equivalent IP phone availablle in the market which works with CUCM 6.1 and above?
Thanks & Regards,
6 Replies 6
ronpatel
Level 8
Level 8
As per Cisco EOX link the 6921 phones whould be good for you. But minimum CUCm version required is 7.1.2
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/end_of_life_notice_c51-683624.html
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Right now we have CUCM 6.1 ver and planning to upgrade to ver 9.0 in 6 months of time from now. We need to procure the ip phones to serve the users for next 6 months to work with 6.1 and later move on to the new ver. What is the best option?
Thanks & Regards,
Closest which I could find is 7931 which is supported in CUCM 6.X also.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps7062/product_data_sheet0900aecd80534259.html
Ronak Patel
Thanks Ronak. 7931G can work with 6.0 and later version and is the closest match to 7911...
Thanks & Regards,
Hello Raffiudeen,
Kindly find the attached pdf that has the Compatible System Information for CUCM 6.1 - Cisco Unified Communications Compatibility Tool
Hope this helps.
Thanks & Regards,
Venkitesh
Thanks Venkitesh. The doc is really useful to find the right end node for our current version of CUCM...
Thanks & Regards,
