321
Beginner
reports for extension mobility
Is there any report on CUCM 6.x shows when the user login and logout using extension mobility feature during period of time for example one month.
2 REPLIES 2
Hall of Fame Cisco Employee
Re: reports for extension mobility
No, you would need to enable EM traces and then parse thru them in order to find out login/logout events to get the info
java
if this helps, please rate
java
Highlighted
Beginner
There is a solution for this.
There is a solution for this. it is called ALM PRO+.
ALM PRO+ allows companies to view ExtensionMobility usage and is able to run detailed reports for usage and management purposes.
  • Centralised administration for all sites/locations using ALM PRO
  • License management and control
  • Advanced reporting on EM usage
  • Extended management reporting options
  • Calculating work space usage
  • Manage user and group profiles
  • Web-based administration
Drop me a PM for more information
Content for Community-Ad
August's Community Spotlight Awards
