Resource unavailable
schoerlin
Hi all,
I did do a QSIG connection from a Cisco 2921 and a Siemens Hipath. All calls from the Siemens were transmitted over this QSIG . This QSIG connection was working without any issues. Without any configuration change, the Siemens devices behind the QSIG were not able any more, to do external calls. But they were able to do calls internally to the Cisco over the QSIG, and they were still reachable from externally.
If I try to do an external call on the Siemens, I get the following error message on the QSIG:
Aug 9 12:07:06.016 CET: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x806E
Aug 9 12:07:06.016 CET: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x806E
Cause i = 0x80AF - Resource unavailable, unspecified
Aug 9 12:07:06.076 CET: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x006E
Cause i = 0x8090 - Normal call clearing
Aug 9 12:07:06.164 CET: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x806E
I already exchanged the DSP`s on the QSIG, but unfortunately I got the same error.
Thanks in advance
Frank
Can you disable "Early Offer support for voice and video calls" and check if that makes any difference.
Mohammed Noor
13 Replies 13
Mohammed Khan
Hi ,
can you  provide the following for a sample call
debug voip ccapi inout
debug isdn q931
debug dial-peer
show tech
show tech voice
Mohammed Noor
Hi Mohammed,
many thanks for your quick reponse.
Attached the debugging of 3 calls, and the outputs of the show tech commands.
T&R
Frank
This is MGCP call flow. Need following logs from GW
debug mgcp events
debug mgcp packet
debug mgcp errors
debug vtsp events
debug vtsp session
debug ccm-manager backhaul
debug isdn q931
Also with Detailed Cisco Callmanager Logs
Mohammed Noor
Hi Mohammed,
here are the logs from the gateway.
Can you tell me which Call Manager Logs you exactly want? I think from the RTMT, but here you also have many options.
T&R
Frank
Follow below link to collect logs from RTMT
https://smbitsolutions.wordpress.com/2010/05/26/how-to-gather-logs-with-rtmt/
Mohammed Noor
Hi Mohammed,
many thanks for the description. Attached the log file from the RTMT.
T&R
Frank
Logs don't cover failed call. You may have collect logs right after simulating a sample call.
Note:Collect logs from all server.
Mohammed Noor
Hi Mohammed,
apologize for that.
Again all logs. I was able to find the call on the RTMT Log (13:37:55), therefore I hope you will see all necessary information.
Thanks in advance!
Frank
Frank
Call failing when it gets extended to SIP Trunk(DEAUUCG1). Can you send me the screenshot of SIP Trunk and SIP Profile configuration.
00311968.001 |13:38:15.572 |AppInfo  |SIPCdpc(219) - outCall_waitRSVPRes_PolicyAndCACRegisterRes: RSVP indicates the call to be cleared: RSVP_EO_RES_Fail_Call
Mohammed Noor
Hi Mohammed,
many thanks for your support.
Attached the SIP Trunk Configuration and the SIP Profile.
T&R
Frank
Mohammed Noor
Hi Mohammed,
you are my hero.
After changing the settings like mentioned from you, it was working.
Many, many thanks for your great support!!!
Frank
I am glad I was able to help you.
Mohammed Noor
