restoring a backup in cucm 7.1.5-no feature found in backup
gregorygout1
I have setup a lab with vmware 5.5, installed cuc, cucm and uccx version 7 for a customer.
I am having issues with restoring a backup from cucm 7.1.5.
I get the message no features found in backup when I try to restore (does not give the option to tick ccm)
my backup contains a sub and a pub, but I want to restore only the pub(did a fresh installation). I have a successful message for the backup in the live server.
I would like to check the trace files for my backup from the CLI.
found in doc to look for
platform/drf/trace/drfMA0
platform/drf/trace/drfConfLib0
I am not 100% sure how to read those from the cli, so any help appreciated!
Thanks a lot
Greg
manpreetsingh46
file tail platform/drf/trace/drfMA0
file tail  platform/drf/trace/drfConfLib0
Suresh Hudda
You can collect these logs using RTMT or CLI (attaching doc for cli) and can read them using Notepad++
Hope you are trying to restore backup on exactly same version of cucm and with same IP address, host name, security password.
Suresh
Hi thanks a lot guys.
after reviewing the logs, I found out my drfcomponent xml file could not be opened. had lots of NULL statements at the bottom.
deleted them and this is now working.
