Return DTMF not working. DTMF Relay on POTS????
telephonypro
Can someone tell me how to turn on DTMF relay on a POTS dial peer or even in global config??? What is happening is when we make a outbound call and the call is connected, an IVR is on the line as the calling party. When the called party presses keypad, DTMF is not returned to the calling party.
I have a AS5350XM with c5350-jk9su2_ivs-mz.124-24.T8.bin IOS
dial-peer voice 156 pots
description Outbound PSTN Dial Peer
destination-pattern 502.......
direct-inward-dial
port 3/0:1:D
forward-digits all
dial-peer voice 997 voip
description Inbound SIP Dial Peer
modem passthrough nse codec g711ulaw redundancy
voice-class codec 1
session protocol sipv2
incoming called-number 502.......
dtmf-relay cisco-rtp rtp-nte
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
IVR -->SIP (AS5350) -->PSTN (POTS) -->Called Party
IVR ------------------DTMF OK----------------------------> Called Party
IVR <----------------DTMF Not Working----------------- Called Party
Brian
azjpiper151
Try using the
dtmf-relay sip-notify
instred of the
JP
