Roles for Users in via LDAP
leighharrison
Level 7
Level 7
Hello folks,
I've got a customer that wants to give "Standard CCM End User" rights to their 7,500 users.
These users are bought in via LDAP and although I can set all of the rights individually, doing that for 7,500 users is a killer!  I also know that I can put users in against the Role, but that's still only letting me do it 250 users at a time.
Is there a way of adding in users from LDAP and giving them a default profile?
LH
Jaime Valencia
Unfortunately there is no way to give users a default role when importing them.
This is asked quite frequently so i'd suggest you to reach your AM and check with him if you can submit a PER on this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
