Route pattern CUCM & Voice Gateway
clark white
Level 2
Level 2
Dears,
I want to verify my route pattern whether the route patten i have configured are correct or wrong ,,at present my PRI is down before going live i want to be confirm my route pattern on  CUCM  and dial-peer on voice gateway are correct.what tool i shld use to verify.
The screenshot for CUCM route pattern are attached.I have selected a discard digit predot
dial-peer voice 1 voip
destination-pattern 4...
session target ipv4:10.10.10.10 -------------this hits to CMCM-PUB  what will happen if CMCM-PUB is down does it will switchover to CMCM-SUB ????
incoming called-number .
dtmf-relay rtp-nte
dtmf-interworking rtp-nte
codec g711alaw
dial-peer voice 3 pots
destination-pattern .T
direct-inward-dial
port 0/0/0:15
forward-digits all
I have verified the voice gateway dial-peer by this command show dialplan number <number> It show me the below output i hope this is becz my E1 is down please correct me if i am wrong.
sh dialplan number 16849755
Macro Exp.: 16849755
No match, result=-1
24 Replies 24
Anas Abueideh
Level 9
Level 9
you need to create another dial-peer pointing the subscriber with lower preference
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
preference 3
session target ipv4:to CMCM-PUB
voice-class h323 1
dtmf-relay h245-alphaunmeric
codec g711alaw
dial-peer voice 2 voip
preference 4
session target ipv4:to CMCM-SUB
voice-class h323 1
codec g711alaw
for incoming calls from pstn you need to create voice translation-profile to translate the pstn called number to 4XX etensions.
voice translation-rule 1
  rule 1 /.*\(4...$\)/ /\1/
voice tranaslation-profile in
  translate called 1
transation-profile incoming in
direct-inward-dial
port 0/0/0:15
forward-digits all
Anas
please don't forget to rate the helpful posts
hi
in addition to anas , please make sure that your gateway  reached to your cucm  and on cucm you can see the ip address of your h323 gateway , in each route pattern do not forget to attach with the route list which  contains your gateway.
thank you
please rate if this will help
Dear's
Please answer below queries
  • How can i verify the configured route patern in voice gatway and CUCM ?? that those are correct any form of generating a dummy call to verify the rotue pattern is perfect.
  • My pilot number is 12345000 playing with 3 digits 000 i have a 1000 DID so according to that what willbe my translation profile
  • I have verified the voice gateway dial-peer by this command show  dialplan number It show me the below output i hope this  is becz my E1 is down please correct me if i am wrong.
     No match, result=-1
Thanks for the above info.
Hello
in your voice gateway , you can use
show dial-peer voice     it will display all active dial-peers
you have also to check registeration of your gatewaybon cucm. try tovshow calls using debug isdn q931
after your E1 is up ,try debug isdn q931 which will show number of calling and called number
thank you
Hello Islam,
As by the command sh dial-peer vocie the POTS dial-peer 3 which is connecting to ISP  is not shown in the command output becz of E1 PRI is down.Am i correct ?????
I shld make a call to PSTN and i shld chk in router whether the call is reaching to router or not by enabling debug isdn q931,,Is is this you are trying to explain me.
please  ???? I am not aware how to configure the translation profile i have to read for this topic but for the glance can you put some shade.
Hello
1- for  show dial-peer voice displays all detailed to configured dial-peers  , make sure that you do  no shut under the dial-peer
2-yes what i need to show calls after h323 gateway registervand e1 is up you can use the below
1- show voice call summary
2-show call active voice
3-debug isdn q931
3- i need to clarrify your dial plan is 4... or 1...  , please clarrify and your pilot number is the number of e1 circuit
I have done the no shutdown for the dial-peer but same below results.
     No match, result=-1
I have a  4 digit ext in my company starting with  5XXX, my pilot number is 12345000 with 1000 DID means from 12345000 to 12345999.
Try putting a # at then end of the number when using the show dial plan command. This character represents the interdigit timeout which is required by your dial-peer destination pattern of .T
For example.
sh dialplan number 16849755#
Hello
please share your configuration .
Thank you
preference 3
destination-pattern 5...
session target ipv4:CUCM-PUB
voice-class h323 1
dtmf-relay rtp-nte
codec g711alaw
preference 4
session target ipv4:CUCM-SUB
voice-class h323 1
description Outgoing Calls to ITSP
direct-inward-dial
port 0/0/0:15
forward-digits all
Still the same, My E1  link is down still my show dialplan number command will work ????
Hello Clarke
Let us help you , can you share your configuration , and please share the log from ( show isdn status).
Thank you
please rate
#sh isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
preference 3
voice-class h323 1
dtmf-relay rtp-nte
codec g711alaw
preference 4
voice-class h323 1
direct-inward-dial
port 0/0/0:15
forward-digits all
You have a problem in layer 1 connectivity to you ITSP ( may be it be physically) , i hope to share the configuration of E1.
ahare all the configuration on your router.
