Route pattern in India
CSCO11921629
Hi.
       I need to configure route pattern in CUCM 8.0 in INDIA. Can any body tell me the route pattern for STD calls, International calls. And one thing is also what I need to configure to PRI to make outside calls. I have added the gateway to CUCM with MGCP.
pankaj sharma
Gordon Ross
Level 9
Level 9
http://en.wikipedia.org/wiki/Telephone_numbers_in_India or http://www.dot.gov.in/numbering_plan/nnp2003.pdf ?
As to making outside calls via the PRI, assuming your PRI is configured correctly, all you need is a route pattern pointing to the PRI. (Altough the slightly better way, is to have a route pattern point to a route list pointing to a route group, which has the PRI circuit in it)
GTG
Please rate all helpful posts.
