Route Patterns
Hi, I am new to cucm, if anyone can help me to create these route patterns.
The range of numbers is:908-685-6660 ~ 6679, 908-203-2560 ~ 2599, 908-203-2400 ~ 2439-
Any help will be appreciated.
5 Replies 5
908-685-6660 ~ 6679  ==>  90868566[6-7]X
908-203-2560 ~ 2599  ==>  90820325[6-9]X
908-203-2400 ~ 2439  ==>  90820324[0-3]X
Maren
908-203-2400 ~ 2439
Single RP, 908[26][80][35][26][456][0-9]X
Response Signature
@Nithin Eluvathingal
I think your single route pattern would allow non-desirable numbers. For instance: 908-285-6409 would be a match. I don't think you can combine three blocks of discontiguous numbers in a discrete way with this pattern.
Maren
Yes you are right.. It will allow non-desirable Numbers too..
@saeedsyedus45074 if you want to allow only the numbers mentioned in the OP, follow Maren's solution.
Response Signature
Jaime Valencia
