Router 2801 conference bridge
gevangelista
I've a cisco 2801 router equipped with 32 ds, but there isn't  any voice card interface.
To configure this device ad a conference-bridge, I need to have some voice interfasce card (bri  or PRI or T1) or not?
Thanks in advance
giancarlo
ronpatel
Level 8
Level 8
You need only PVDM's to have Conf resources.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ok thanks
the followìng config on router it's correct?
@ GW
GW_2801(config)#sccp local
GW_2801(config)#sccp ccm identifier 1 version 4.0
GW_2801(config)#voice-card 0
GW_2801(config-voicecard)#dsp services dspfarm
GW_2801(config-voicecard)#exit
GW_2801(config)#dsp profile 1 conference
GW_2801(config-dspfarm-profile)#associate application sccp
GW_2801(config-dspfarm-profile)#maximum sessions 2
GW_2801(config-dspfarm-profile)#no shutdown
GW_2801(config-dspfarm-profile)#exit
GW_2801(config)#sccp ccm group 1
GW_2801(config-sccp-ccm)#associate ccm 1 priority 1
GW_2801(config-sccp-ccm)#associate profile 2 register CFB123456
GW_2801(config-sccp-ccm)#bind interface
GW_2801(config-sccp-ccm)#exit
GW_2801(config)#dspfarm
@ CallManager
Service >> Media Resource >> Conference Bridge
Add a New Conference Bridge
Conference Bridge Type : Cisco IOS Enahanced Conference Bridge
Conference Bridge Name : CFB123456
Device pool :
No its not correct, you need to reference the same profile number in the association as you used when you create the CFB profile.
GW_2801(config-sccp-ccm)#associate profile 1 register CFB123456
Please all rate useful posts
Response Signature
