Router 4331 to configure R2 signalling
soporte-vzla
Hi everyone,
I am configuring a 4331 with a NIM-2MFT-T1/E1 but I can´t  configure the R2 signalling, the command for r2-digital is not in the router.
Router_Voice(config)#controller e1 0/1/0
Router_Voice(config-controller)#ds0-group 0 timeslots 1-15 type r2-digital
% Invalid input detected at '^' marker.
Router_Voice(config-controller)#ds0-group 0 timeslots 1-15 type ?
  e&m-delay-dial       E & M Delay Dial
  e&m-immediate-start  E & M Immediate Start
  e&m-melcas-delay     MEL CAS (CEPT) E & M Delay Start
  e&m-melcas-immed     MEL CAS (CEPT) E & M Immediate Start
  e&m-melcas-wink      MEL CAS (CEPT) E & M Wink Start
  e&m-wink-start       E & M Wink Start
  fxo-ground-start     FXO Ground Start
  fxo-loop-start       FXO Loop Start
  fxo-melcas           MEL CAS (Mercury) FXO
  fxs-ground-start     FXS Ground Start
  fxs-loop-start       FXS Loop Start
  fxs-melcas           MEL CAS (Mercury) FXS
Can you help me please?
Here are the show version and show run
Router_Voice#sh ver
Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 05-Oct-15 11:24 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router_Voice uptime is 2 hours, 16 minutes
Uptime for this control processor is 2 hours, 17 minutes
System returned to ROM by reload
System image file is "bootflash:/isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appx             None             None             None
uc               uck9             Permanent        uck9
security         None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 1687137K/6147K bytes of memory.
Processor board ID FLM2101W1BJ
3 Gigabit Ethernet interfaces
2 Channelized E1/PRI ports
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
Router_Voice#sh run
Building configuration...
Current configuration : 2489 bytes
! Last configuration change at 19:38:14 UTC Mon Jun 5 2017
version 15.4
no platform punt-keepalive disable-kernel-core
hostname Router_Voice
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
card type e1 0 1
enable secret 5 $1$NJEv
aaa new-model
aaa session-id common
ip domain name Mer.com
subscriber templating
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12 advertise-only
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  call start slow
 sip
  header-passing
  registrar server expires max 3600 min 3600
voice-card 0/1
 dsp services dspfarm
 no watchdog
voice-card 0/4
 no watchdog
license udi pid ISR4331/K9 sn FDO205124SC
username Cisco secret Cisco
redundancy
 mode none
controller E1 0/1/0
 framing no-crc4
controller E1 0/1/1
 framing no-crc4
interface GigabitEthernet0/0/0
 no ip address
 speed 1000
 no negotiation auto
interface GigabitEthernet0/0/0.90
 encapsulation dot1Q 90
 ip address 172.X.X.X 255.255.255.0
 no cdp enable
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/4/0
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.19.90.1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input ssh
network-clock synchronization automatic
end
Jitender Bhandari
Can you compare the config from link below.
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/isr4400swcfg_chapter_010010.html#task_D69A71E834B641808CCDFA5443266E0B
Summery
E1 R2 Signaling Configuration
To configure the E1 R2, perform these steps:
Before You Begin
Before you attempt this configuration, ensure that you meet these prerequisites:
  • R2 signaling applies only to E1 controllers.
  • In order to run R2 signaling on Cisco 4000 Series ISRs, this hardware is required:
  • NIM-MFT-1T1/E1 or NIM-2MFT-T1/E1 or NIM-4MFT-T1/E1or NIM-8MFT-T1/E1 or NIM-1CE1T1-PRI or NIM-2CE1T1-PRI or NIM-8CE1T1-PRI
  • Define the command ds0-group on the E1 controllers of Cisco 4000 Series ISRs.
  • Cisco IOS XE software release 15.5 (2)
SUMMARY STEPS
1.    Set up the controller E1 that connects to the private automatic branch exchange (PBX) or switch.
2.    For E1 framing, choose either CRC or non-CRC
3.    For E1 linecoding, choose either HDB3 or AMI.
4.    For the E1 clock source, choose either internal or line. Note that different PBXs have different requirements on the clock source.
5.    Configure line signaling.
6.    Configure interregister signaling.
7.    Customize the configuration with the cas-custom command.
Refer to the link above for more details
(Rate if it helps)
JB
