RTMT Alert central "HardwareFailure events generated"
Hi everone,
i have a problem with call manager 6.1.5 where i discovered the problem form RTMT as clered below
under Hardware failure
At Sun May 20 12:22:31 EEST 2012 on node x.x.x.x, the following HardwareFailure events generated:
hwStringMatch - cmaidad[3862]: Accelerator Board Status Change: Slot 1. Status is now Temporarily Disabled.
what dose "Accelerator Board" means and what is the recommended actions/solution
Chris Deren
See similar thread here:
https://supportforums.cisco.com/message/3027003#3027003
HTH, please rate all useful posts!
Chris
thanks chris, but i see that is a diffrent alert as it is cleared that it is about the battery and other concerning the hard drive
not the Accelerator Board Slot 1 as in my case
