RTMT alert
saif musa
Level 4
Level 4
Please what that alert means exactly..
((At Tue Oct 14 20:37:52 AST 2014 on node 172.23.167.10, the following HardwareFailure events generated:
hwStringMatch - cmaidad[3054]: Accelerator Board Status Change: Slot 1. Status is now Temporarily Disabled.
hwStringMatch - cmaidad[3054]: Accelerator Board Battery Failed: Slot 1. ))
2 Accepted Solutions
Gordon Ross
Level 9
Level 9
The battery on the RAID card is dying. You'll want to at least remove it so it doesn't make a mess inside your server.
GTG
Please rate all helpful posts.
The batteries are on the RAID card. They allow a feature called write-back: Writes to disc are temporarily held in RAM so they can be better ordered to improve performance. The batteries are needed in case the server looses power and can't write the data to disc (which it claimed to the operating system that it had written to disc). Next time the server powers up, the RAID card will flush those writes to disc. If the RAID card detects the batteries are dead, it will disable this write caching, which can impact server performance.
You don't mention which exact model of server you have. On the HP based servers, (which I think this is, based on the message) the batteries are quite easy to replace: Power the server down, pop the lid, and you should see a battery module on the RAID card near the back. On the MCS7845-H (Which is a rebranded HP DL380G5) the batteries are clipped onto the RAID card and connect through a small fly-lead. The batteries on the RAID cards on the MCS 7845/DL380G5 are dire. We had to replace all our batteries at least once.
GTG
Gordon Ross
Level 9
Level 9
GTG
Thanks Gorden, please could you tell me also whats the roll of these batteries inside CM ? and if there is any documents or instructions on how to replace or how to remove it.
Saif Musa
GTG
Gordon, thanks for replying..
My server is IBM based MCS7835H2. I'm wondering if the server flash the alarm even if the electrical power not shutdowns the server ??. cause i have another server in the same rack both on the same power supply and there is no alarm on the second one.
Saif Musa
