Hi,i wondered how to check replication betweek publisher and subscriber via a request SNMP ...Thanks for your replies !Best regards,Guillaume
Hi I am trying to set up multicast for music on hold on the cucm 9. on the cucm, I enable multicast audio sources on MOH server, using base IP 239.1.1.1, and set increment multicast on " ip address" however the multicast IP address keep changing, so...
Hello all,Is there any way to configure Corporate Directory Exchange between clusters without the helping of LDAP? Thanks in advanceBahlul
We're running a BE6K with CUCM, CUC, and CPCP 10.5. Our Unity Connection isn't exchange integrated. But some end users prefer to have their voicemails forwarded to email. I can do that via the Message Actions options in Unity Connections.However, ...
We have a number of remote sites connected with ASA5505s and even a few old PIX501s with site to site VPN. Everything works great, routing is flawless and 7940/60s always work perfectly. The “problem” is that 7945Gs won’t register remotely. If I plug...
guys i am running this setup and need some help:cucm 9uccx 9CAD and CSD on desktop...now apply agent login on ip phones...but when calls come CADAT not coming up on screen...how can i get this CDATA pop up when incoming calls have on ip phone?>
Claimer: I initially post it here and was told to post again here to get more feedback.Hi, I thought I am clear on this but not sure after worked on a customer CUCM server...I will try my best to explain. Lets only talk software based media resources...
Hello, i am looking for configuration guide such as, call-pickup,call forward,transfer, conference, etc,etc when VG in in SRST mode (mgcp fallback)can anybody route me to configuration guidethanks
Dear Sirs,I am fresh in Cisco Telephony system (CME). We install the CME 9.1 with MeetMe conference session. Also we have live record button for recording conversation to our mailbox. However, we found that live recording button is not support in Mee...
We are running CCM 5.1.3. I have a TAC case open on this, and I have a work around, but I wanted to see if anyone else was having this problem.We are not using G.722 in our network, even though we have the phones to support it, because it is not sup...
Hi,Is there some sort of rule of thumb to follow when working out how many phones you will be able to power on a switch? e.g If I have a stack of 4 x 3750X how do you work out available power for phones? Does it make a difference if the switches run...
Hi ,when i´m dialing with the DNA / Phones the call is routed ( result is ok.)but when i´m dialing on the device ( the same phone es in DNA) i get fast busy ????
hi, i am about to perform a migration of CM 8.0 from an old MCS server to a UCS server. i tried this in the past where i used one of the CM ova files for the new virtual machine. i don't remember exactly which one, i may have been the 2500 ova, but...
I am running a CUCM10.5 with 8851 model phones, along with older 7961 phones.We are LDAP integrated for directory, using 4 digit internally with LDAP phone number listed 10 digit.I created a translation pattern stripping 6 digits and calling from the...
Hello everyone;I have a cisco 3745 voice gateway already configured and working.I want to modify the configuration for one directory number ( for example replacing 1000 by 2000).what are the modification that must be done, using witch commands.N.B ...
| Subject | Author | Posted |
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
