RTMT Specific PRI Active Channel Graph
pjsooner7
Is there a way in RTMT to see the active MGCP PRI B channels for a specific span?  It appears the only real time graph is a total count of all the active B channels registered to the cluster consisting of multiple PRIs, nothing span specific.  Any pointers or alternate ways of doing this would be greatly appreciated.  I have pulled CDR records and translated into line graph averages, but would like to be able to see a specific PRI line graph in real time instead of doing a constant "sh voice call summary" over and over on the gateway.  This is my 1st time to post on the Cisco Support forums, be gentle.  :)
Paul
Hi pjsooner7,
welcome to the Community.
Try this:
In RTMT > Performance > StandAlone Cluster > <CUCM's IP Addr> > Cisco MGCP Gateways:
- PRIChannelActive
- PRISpanInService
Hope this helps.
Hi pjsooner7,
Try this:
- PRIChannelActive
- PRISpanInService
Hope this helps.
pjsooner7
Well that was easy enough.  Thank you Marcelo!
