08-03-2016 03:23 PM - edited 03-17-2019 07:43 AM
Dears,
RTP Payload fixed many problem i faced in DTMF and video conferencing
however my question what it does to fix these problem
any technical answer for this question
Thanks all
08-03-2016 05:30 PM
Zaher,
what do you mean by "RTP Payload fixed many problem i faced in DTMF and video conferencing"?
are you asking what the significance of RTP Payload is?
cheers
08-03-2016 11:07 PM
Hi Dennis,
Part of my question YES, but the other part all these types what exactly they do
08-04-2016 09:15 AM
You question isn't clear. Can you please reword it.
If you are asking what payload type does. It is a value which determines the encoding/decoding mechanism. audio rtp, its important for both endpoints to agree same rtp payload type to locate the right encoding/decoding algorithm. For video rtp, payload types can be different in each direction.
08-16-2016 12:09 PM
Hi Mohammed,
I checked many documents all of them say the same encoding/decoding mechanism.
Okay for that
For me how can I know which type should I use or which value from all RTP-Payloads
