RTP Payload
Zaher Juha
Dears,
RTP Payload fixed many problem i faced in DTMF and video conferencing
however my question what it does to fix these problem
any technical answer for this question
Thanks all
Dennis Mink
Zaher,
what do you mean by "RTP Payload fixed many problem i faced in DTMF and video conferencing"?
are you asking what the significance of RTP Payload is?
cheers
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Part of my question YES, but the other part all these types what exactly they do
You question isn't clear. Can you please reword it.
If you are asking what payload type does. It is a value which determines the encoding/decoding mechanism. audio rtp, its important for both endpoints to agree same rtp payload type to locate the right encoding/decoding algorithm. For video rtp, payload types can be different in each direction.
Hi Mohammed,
I checked many documents all of them say the same encoding/decoding mechanism.
Okay for that
For me how can I know which type should I use or which value from all RTP-Payloads
