SAP R3 QoS
ladislao2006
Hello, please anybody knows about what's the SAP R3 size packets in order to provide Bandwidth QoS?
Marwan ALshawi
the following is config example from cisco press regarding SAP policing maybe helps u:
CAT3550(config)#ip access-list extended SAP
CAT3550(config-ext-nacl)# permit tcp any range 3200 3203 any
CAT3550(config-ext-nacl)# permit tcp any eq 3600 any
CAT3550(config)#class-map SAP
CAT3550(config-cmap)# match access-group name SAP
CAT3550(config)#policy-map UNTRUSTED-SERVER
CAT3550(config-pmap)#class SAP
CAT3550(config-pmap-c)# set ip dscp 25 ! SAP is marked as Mission-Critical
CAT3550(config-pmap-c)# police 15000000 8000 exceed-action policed-dscp-transmit
! Out-of-profile SAP is marked down to Scavenger (CS1)
good luck
if helpful Rate
Joseph W. Doherty
Sorry I don't, but R3 isn't real tolerant of delay or drops. Best thing would be guarantee ample bandwidth via QoS (perhaps initially 50% with CBWFQ), monitor actual bandwidth demand of R3 in your environment, then adjust bandwidth guarantee.
