Saved voice mail Transfer
andrew.king
Can a saved voicemail message be transferred to another persons voicemail?
A user has a saved message on her phone but its meant for someone else.
2 Accepted Solutions
Rob Huffman
Hi Andrew,
The easiest way to do this would be to have the user log in
to her voicemail, pull up the message and just forward it to the
proper recipient
What VM system?
Cheers!
Rob
Rob Huffman
Hi Andrew,
Can you please try;
Step 5 Use the following keys to manage the message after you have listened to it:
Key(s)
Action
Key(s)
Action
Replay message
6
Save as new
Save
7
Rewind message
Delete
9
Play message properties
Reply
(Resend original message when responding to an NDR.)
Save as is
42
Reply to all
Cancel or back up
44
Call the user1
Help
Forward message
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/user/guide/2xcucug070.html
Cheers!
Rob
5 Replies 5
Rob Huffman
Hi Andrew,
proper recipient
What VM system?
Cheers!
Rob
Hi Rob
It's Cisco Unity connection administration Version 2.1.2
Rob Huffman
Hi Andrew,
Can you please try;
Key(s)
Action
Key(s)
Action
Replay message
6
Save as new
Save
7
Rewind message
Delete
9
Reply
Save as is
42
Reply to all
Cancel or back up
44
Call the user1
Help
Forward message
Cheers!
Rob
Thanks Rob
I appreciate it.
Excellent Thanks
