05-13-2013 02:31 PM - edited 03-16-2019 05:17 PM
Hi everybody
A quick question about SCCP phone boot up process.
This is my understanding when phone boots up:
1. SCCP phone obtains the Power (PoE or AC adapter).
2. The phone loads its locally stored firmware image.
3. The phone learns the Voice VLAN ID via CDP from the switch.
4. The phone uses DHCP to learn its IP address, subnet mask, default gateway and TFTP server address.
5. The phone contacts the TFTP server and requests its configuration file. Each phone has a customized configuration file named SEP<mac_address>.cnf.xml created by CUCM and uploaded to TFTP when the administrator creates or modifies the phone.
6. The phone registers with the primary CUCM server listed in its configuration file. CUCM then sends the softkey template to the phone using SCCP messages.
Please focus on step 5, among other things, this configuration file also contain the " firmware file " name( or load) that a phone should have. So when SSCP phone receives this config file, it checks its own firmware against the firmware 's file name in the configuration file. If it does not match, phone then request the firmware file mentioned in config file from tftp server and loads it.
After that phone proceeds to step 6( phone registration)
The important thing to note is if there any mismatch between firmware on the phone and the firmware specified in config file. it is resolved at step 5 i.e before phone attempts to register with CUCM.
This is my understanding.
However, I find some conflicting information.
For example consider the following from the link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/a02tftp.html
After obtaining the configuration file from the TFTP server, a device attempts to make a TCP connection to the highest priority Cisco Unified Communications Manager in the list that is specified in the configuration file. If the device was manually added to the database, Cisco Unified Communications Manager identifies the device. If auto-registration is enabled in Cisco Unified Communications Manager, phones that were not manually added to the database attempt to auto-register in the Cisco Unified Communications Manager database.
Cisco Unified Communications Manager informs devices that are using .cnf format configuration files of their load ID. Devices that are using .xml format configuration files receive the load ID in the configuration file. If the device load ID differs from the load ID that is currently executing on the device, the device requests the load that is associated with the new load ID from the TFTP server and resets itself. For more information on device loads,
Above load id refers to firmware.
According to above paragraph, any mismatch of firmware i.e if the the phone is running different firmware from the one specified in config file, is resolved when the phone attempts to register with CUCM.
I thought any mismatch between firmware on the phone and the firmware specified in the config file is resolved when phone contacts tftp and requests its configuration file. However the above paragraph suggest that phone does that when it attempts to register with cucm.
I appreciate your help.
thanks and have a great day.
Solved! Go to Solution.
05-13-2013 05:15 PM
Sarah,
Have alook at this link.
This is what cisco teach
http://www.ciscopress.com/articles/article.asp?p=1745631&seqNum=7
Alex.
Please rate useful posts.
05-13-2013 06:28 PM
This figure provides an overview of the startup process for a Cisco IP Phone if you are using a Cisco Catalyst switch that is capable of providing Cisco prestandard Power over Ethernet (PoE).
Rahaul Aggarwal
05-13-2013 05:15 PM
Sarah,
Alex.
05-13-2013 06:28 PM
Rahaul Aggarwal
02-01-2017 09:51 AM
Very helpful and succinct response Rahaul.
In a windows server 2012 DHCP environment, are you able to confirm if the phone behaves in a similar manner to other clients in that:-
The first DHCP request will recieve an IP address offer which will have a lease duration of 30 minutes
After 30 minutes the IP phone will issue a DHCP renew request and the next offer will be for the full lease period (in our case 7 days).
With a lease period of 7 days, can I expect the phone to issue another renew request at 3.5 days (50% of lease period) or is this behaviour specific to windows clients?
I'm trouble shooting a scenario where an IP phone is dropping a call mid-conversation and then displaying UCM down features disabled.
It appears (from the DHCP logs) to be assigned an address, request a renewal of that address 30 minutes later and then release the address 38 minutes after that.
Of the 3500 phones we have and with only 5 reports of this behaviour which points to a badly behaved phone. All of this is based on CUCM 11.0, Cisco 7961 running 9-4-2SR1-1S).
Sorry I've hi-jacked this thread with irrelevant content now but I was just trying to explain the reasoning behind my question.
Best
Richard
02-01-2017 10:53 AM
Hijacker:)
