SCCP phones have correct time format but SIP Phone have a wrong time zone and incorrect date format
jchevalon
I currently have about twenty phone SCCP
And one SIP phone
I have an ISR2901, CME 10.5. , and I have set up an NTP
All SCCP phones have the correct date format, and the correct time.
My SIP Phone is registered, all work perfectly.
The only concern I have is the time.
I used unsuccessfully these links:
https://supportforums.cisco.com/discussion/11717026/clock-sip-phone-3905
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html
I followed the links above and here where I am for Voice Register Global:
voice register global
 mode cme
 source-address 192.168.5.60 port 5060
 max-dn 200
 max-pool 42
 tftp-path flash:
 create profile sync 4321001012373626
 ntp-server 192.168.5.60 mode directedbroadcast
NTP server is my CME (192.168.5.60) , i am in Switzerland and i have try too with NTP on this site: http://www.pool.ntp.org/zone/ch whithout success.
I did with and without, it's the same thing.
I made a create profile after each of these tests
thanks in advance for your help
2 Accepted Solutions
I believe that indexing has not been changed in the later revision.... if so, configure it as follows;
timezone 28
You simply need to configure the timezone 'index'. In the version I've, it's 28 for CEST (UTC + 120/mins).
- Vivek
Good...
time-format 24
date-format D/M/Y
Don't forget to give 'create profile' command and restart the phones.
- Vivek
7 Replies 7
Vivek Batra
Didn't you try with configuring timezone command under voice register global?
- Vivek
Hi Vivek,
I have try but i have "invalid input" each time, I can not get it directly on "voice register Global"
I get can not be properly understand the syntax.
My time zone is:
CEST
Central Europe Summer Time, as UTC + 2
timezone 28
- Vivek
Its ok now concerning the time, its correct
but it is the 12h time format and mm/dd/yyyy
I would like to it to be:
24h time formats and dd / mm / yyyy
Do you know how i can set up it?
Good...
time-format 24
date-format D/M/Y
- Vivek
Great,
its work.
Thank you again!!
You're most welcome!
- Vivek
