UnityConnection 8.5 - web user inbox error
fei he
Level 2
Level 2
I've been encounting this error message while access inbox:
Unable to retrieve spec for http://<UnityConnection IP>/inbox/gadgets/msg/msg-gadget.xml. HTTP error 500 error1.JPG
UnityConnection version - 8.5.1ES47.12900-47
Any idea to resolve this?
Hi.
Does this post fit with your issue?
https://supportforums.cisco.com/thread/2113505
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
That link looks similar but exactly as i encounted error 500 not error 504.
Cheers
Hello everyone,
Did you solve this problem ?
Thanks for any answer
Benoit
travisbarden
I have the same error 500 in 8.6. If I access the site via the IP address it works. Using the DNS name I get that error. I know it used to work earlier this year but stopped recently. We did change the MAC address and rehost the licenses after changing the SMTP address. Other than that, I don't think anything else changed.
