SCCP phones to SIP
midhun_km
Hi Dears..
Is there any method available in CUCM 8.0 (3a) to change the protocol of IP Phones.
All phones are registred with SCCP.
I want to change to SIp for some testing.
what is the solution...?
Is there any other method avilable other than manually delete SCCP phone and , then again register with SIP...?
good day.....
4 Accepted Solutions
Amit Divekar
Hello Midhun,
                    This is definately possible..
Here is the procedure for the same:-
1. Log-in to CUCM Publisher go to Bulk Admintration>Phone Template & create a template for the model of phone that you wish to migrate from sccp to sip, for example ( Phone Type-7970>device prtocol sip
2. Once the template is made go to  Bulk Admintration>Phones>Migrate Phones > sccp to sip
3. Add the template & run the job according to your convinience
Do let me know if this helps.
Please rate the posts if they are helpful
Amit
Hi Midhun,
If you won't do step 8,then if any phones config got erased or if you perform factory reset of the phone and phone tries to download the firmware again , they will again download the SCCP firmware and tries to auto Register themselves as SCCP endpoints, If the auto registeration has been turned on and also the new phones which you plug in will auto register themselves with the protocol mentioned in this enterprise parameter.
PS: Rate if you find the info useful.
sumit
Hi Midhun,
If The auto registeration is turned off then you can skip.
PS:Plase Rate if you find the info useful.
Sumit
Hello Midhun,
                   The step 8 will only come in handy when you have auto-registration enabled in your cluster & you wish to plug in phones & that they would accepted by the Cucm System.
I understand that we do not have Auto-Reg enabled so we can skip that step as we are just trying to move a few phones from sccp to sip.
Hope this clarifies.
Do let me know if this helps..
Do rate if you find this post useful
Amit.
8 Replies 8
Amit Divekar
Hello Midhun,
Amit
Dear Amit,
Thanks for the update.
I got full steos from Cisco, Please find the detailed steps below.
Good  Day _ Bro.
1.Go to Cisco CallManager Administration and choose Bulk Administration > Phones > Migrate
Phones > SCCP to SIP.
2.Click Find after you select/enter the appropriate search criteria to list the phones that need to be
migrated.
3. Click Next and choose the phone template from the drop−down.
4. Enter the job description in the Job Information area.
5.Click Run Immediately in order to migrate phone records immediately or click Run Later in order
to migrate at a later time.
6.Click Submit in order to create a job for migrating the phone records.
Note: After you submit a job for migrating phones from SCCP to SIP, make sure that you reset these
phones. In order to reset the phones, choose Bulk Administration > Phones > Reset/Restart Phones
> Query.
7.When the Migrate job is submitted, choose Bulk Administration > Job Scheduler in order to
schedule and/or activate this job.
If it remains in the Pending state, you might need to activate the Bulk Provisioning Service under the
Serviceability > Tools > Service Activation page. Refer to Activating Bulk Provisioning Service for
more information.
8.Go to Cisco CallManager Administration, choose System > Enterprise Parameters and change Auto
Registration Phone Protocol to SIP (SCCP is the default). Then restart the Cisco CallManager service.
Refer to Autoregistration with Multiple Protocol Support for more information.
Note: In order to revert back to SCCP, you need to delete the SIP phone, set Auto Registration Phone
Protocol to SCCP and then let the phone re−register as SCCP.
Hi amit,
i done the same .....using the step ny step : my previous post.
is there any need to do the 8 th step below shown..?
Thanks.....
Hi Midhun,
sumit
Hi Sumit,
If the auto registration is turned OFF - for an envirimment.
I think we ca eliminate the Step 8 ...
Right.....?
Good day......
Please Update.
Hi Midhun,
Sumit
Hello Midhun,
Amit.
Thanks All,
Rated as Correct Answer
