Searche result in corporate directory
omanetcisco
I'm asking if i can limit the search result in corporate directory for specifics users, so when the user make a searche at the corporate directory, it will find just the users he is authorized to found.
Best regards.
2 Accepted Solutions
Jaime Valencia
No, that's not possible with the built-in corporate directory, you would need to either build your own directory or buy a 3rd party directory which has that capability.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
java
Dear Jaime,
There is any configuration guide on how to built a directory.
Documentation for that is over at DevNet, I believe there's also a sample directory script.
java
Dear,
I didn't found it, can you please share the link?
Best regards.
