Secure Call
Andersen_M
I have a problem with secure call, my phones will not switch to secure mode when I call through a PBX. If I make a direct call (peer to peer), my phones will switch to secure mode.
I read in the manual that the secure call establishment relies on exchange of information embedded in message bodies of SIP INFO requests/responses, the service provider must maker sure that their infrastructure will allow the SIP INFO messages to pass through with the message body unmodified.
I tried to use a SIP proxy to eavesdrop traffic, but it didn't work with peer to peer call. Therefore, it was not possible to compare peer to peer calls with regular calls through the PBX.
Now to the question, what kind of SIP INFO messages must pass through with the message body unmodified?
The call is sending out RTP/AVP instead of RTP/SAVP.  There are two catches with trying to setup a secure call, you cannot have a media termination point or transcoder in the call flow for the call to be setup as secure:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_1/secugd/secuview.html#wp1089060
If the call is going out to the PSTN, the gateway that interfaces with the PSTN connection would need to be configured for encryption too in order to establish an external secure call, even though security is only really guarenteed to the gateway.
Joseph Martini
How's the PBX connected to call manager?  Typically the initial INIVITE will contain the secure information such as SAVP for secure RTP and transport TLS with a crypto line.  Did you get a certificate from the PBX/provider to upload to your call manager to accept the TLS handshake?
Thanks for the response. I'm not sure of how the PBX is connected, I don't work with the phone system.
Today, I know a little bit more of what is working and what is not working.
Phones will switch to secure mode if I call from one extension to another extension, the problem is when i call through the phone company.
I'm not sure if this will cause the issue, but I think so.
The phone I call from send this info: m=audio 16406 RTP/AVP 0 2 4 8 18 96 97 98 100 101
The phone at the other end get this: m=audio 10068 RTP/AVP 0 8 3 101
It looks like the SIP INFO messages do not pass through with the message body unmodified.
I'm not sure of how to solve this problem, maybe reroute specific calls over the internet.
Thanks for the answer, it loks like I have to skip the PSTN and reroute all secure calls through a VPN connection.
