Freeftpd not working properly in Windows 7 64-bit
Brian Carlson
Level 4
Level 4
I recently upgraded to Windows 7 64-bit from XP, and  I've noticed that Freeftpd doesn't work properly anymore.  The windows  don't appear to render properly, for example drop-down arrows that  should appear on the right side of a window are cut off.  Also, the  program is locking up shortly after starting it.
Has anyone found how to get Freeftpd to work with Windows 7, or could anyone recommend an alternate FTP/SFTP app?
Thanks in advance!
Leo Laohoo
Try TFTPd32.
Please don't forget to rate our useful posts.  Thanks.
technobird007
Try using normal fonts, as of now you are using large.  Hope this helps!  (use a DPI of 96)
Chris Lee
Filezilla is another one - not as finicky as freeftpd....
