Secure or limit access to TFTP Server on CUCM
Victor_Gonzalez
Hello
I want to know if there is a way to limit access to the TFTP server of the CUCM or apply security to deliver the files that the ip phones needs but only
to the ip phones or CIPC not to other type of device such as a computer.
Im asking this because a security network scan tool detected the following files from the TFTP on the CUCM :
gkdefault.cfg
RINGLIST.DAT
SEPDefault.cnf
SIPDefault.cnf
XMLDefault.cnf.xml
i will appreciate your recommendations
Regards!
Jaime Valencia
No way to limit TFTP access on the server itself, you can even download phone config files to your computer.
You would need to either use ACLs on your network, or if you want security on CUCM (authentication/encryption) enable that on CUCM.
You may follow the CUCM security guide for such task.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Hi Jaime V.
So, if i decide to  implement security on CUCM, this will accomplish what i mentioned  before? or either way i need to apply an ACL
The quickest way to do it would be using an ACL as you mentioned.  I have a doubt about this, im pretending apply the ACL to permit tftp  access only from the Voice Segments and deny the data segments but if i  do this, it would be affected the CIPC's also, that utilize the data  segment or am i wrong?
