Sending asterix and pound sign to PSTN
Tomasz Bres
Hello
I need to send code like *21*xxxxxxxxx*yyyyyyyyy# to PSTN operator.
I'v tried with destination patern, vioce translation-profile and all I was abble to do is sending:
Called Number=*21*xxxxxxxxx*yyyyyyyyy or
Called Number=*21*xxxxxxxxx*yyyyyyyyyT
How to send # (pound sign) to PSTN?
7 Replies 7
Ayodeji Okanlawon
According to cisco's documentation, You can use both in your destination-pattern.
In addition to wildcard characters, the following characters can also be used in the destination pattern:
Asterisk (*) and pound sign (#)—These characters on standard touch-tone dial pads can be used anywhere in the pattern. They can be used as the leading character (for example, *650), except on the Cisco 3600 series.
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html
Can you send your dial-peer config..
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
dial-peer voice 720 pots
destination-pattern *21*...................
port 0/0/0
forward-digits extra
Why dont you try...
destination-pattern *21*..................#
port 0/0/0
forward-digits all
Result is:
atch Rule=DP_MATCH_DEST; Called Number=*21*xxxxxxxx*yyyyyyyyyT
049088: //-1/23D4BBBCA5E7/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
049089: //-1/23D4BBBCA5E7/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
What system are you using? Are you using CUCM or CCME?
Cisco Unified Communications Manager Express Version 7.0(0)
Tomasz,
The reason is that . is not a valid wildcard for * or # - there isn't one. You would have to specifically put them in their position in the destination pattern.
Hope that helps.
