Server Serial Numbers from CLI/OS administration page
Derek McCormick
I am trying to retieve server serial numbers from some of my IPT customers. When I issue the show hardware command from the CLI/OS admin page, on some versions of CCM it shows the serial number and in other versions it doesn't. There doesn't seem to be a pattern to it. Has anyone come accross this before? Is there an alternative way of getting serial numbers remotely from cli and os admin page?
Derek
Rob Huffman
Hi Derek,
You are most likely seeing this;
CSCso99275            Bug Details
Show Hardware command does not show Serial number of server
Symptom:
'show hardware' from cli and gui does not display serial number of the server
Conditions:
CUCM 6.x and above. Issue does not exist with CUCM 5.x (GUI)
Workaround:
Use SNMP to find the serial number from the CLI:
-An SNMP community string (at least readonly) must be configured, if this hasn't already been done. The following doc discusses configuring a community string:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/admin/sasnmpv1.html#wp1063451
In the below example, the community string is "public".
-Use the following command from the CLI of the server you wish to find the serial number for:
(for HP servers)
utils snmp walk 2c public 127.0.0.1 .1.3.6.1.4.1.232.2.2.2.1.0
(for IBM servers)
utils snmp walk 2c public 127.0.0.1 .1.3.6.1.4.1.2.6.159.1.1.60.1.1.3.6.115.121.115.116.101.109
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.0
Fixed-In
7.0(0.39700.90)
6.1(2.9901.31)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
6.1(3.1000.16)
6.1(3.9999.1)
Hope this helps!
Rob
