Service cannot be Activated or Deactivated due to Database Update Failure
Nguyen KeThuc
Hi all,
I am using CUCM version 7.1. After I install subscribers, I can not start any services in Sevice Activation page. The publisher is ok. Error message:
"...Service cannot be Activated or Deactivated due to Database Update Failure".
Any ideas for me.
27 Replies 27
Hi Aman,
Please review screen capture:
Thuc
Hi Thuc,
How many subscriber servers u have in cluster ?
regds,
aman
Hi Aman
I have two subscriber servers (10.15.242.65/66) in my cluster. The Publisher is 10.15.242.64.
Thuc
Hi Thuc,
The reason why I asked since the Subscriber hostnames have been SUB1 and SUB3 , SUB2 was missing.
regds,
aman
Hi Aman,
As I mentioned, I have two subscriber servers first(sub1 and sub2) and then I I shutdown  sub2 and install a new subscriber server(sub3) with same sub2's IP address. So, you just see sub1 and sub3.
Thuc
Hi Thuc,
Now when u try to start CCM service on SUB3 , what is the message u are getting ? please share if any.
Any reason why u changed the hostname to SUB3 even though IP adddress is same.
regds,
aman
Hi Aman,
When I activate the services on sub3, the message displays : Update Operation Successful
None of reason for changing hostname. Just for test.
Thuc
Hi Thuc,
Can u try restarting the SUB3 server and check whether CCM service is starting or not?
regds,
aman
Hi Aman
After I restart Sub3, the CCM service is still started properly.
Thuc
Hi Thuc,
Did not understand, is CCM service working now after restarting SUB3 server?
regds,
aman
Hi Aman,
No. I mean that CCM service in Sub3 is working, not working with Sub1.
Thuc
Hi Aman,
A good news ! Now I can activate all services in Sub1. I checked network configuration in Publisher server and Sub1 and see that: DNS is not enable in Publisher server but it is set in Sub1. I removed DNS configuration from Sub1 and run Utils dbreplicate reset all. Then, I restart Sub1. Now DB replication status is 2 for all servers.
I wonder how to debug this issue? I just guess and check again and again. That is not good way. Could you share your experience with me?
Thuc
Hi Thuc,
What I can say is that if u enable DNS on one server in a cluster and not on others, the IP phones won't register because of  hostanem to IP address or vice versa resolution.
Either u disable on all servers or enable on servers. Also, have u configured hostname in CUCM or IP addresses.
Do u have DNS in setup?
regds,
aman
