Bookmark
Subscribe
769
Service module ISM install software protocol fail
allahverdiyev
Hi, I have ism-sre-300-k9 installed on 2901 router. Module status is failed. Reset, reload didn't help. When I try service-module ism0/0 session command, it asks username and password, but I don't know credential. Password reset failed.
Router#service-module ism0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 67
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
CPU Frequency: 1068 MHz
Memory Size: 493 MB
Disk 0 Size: 4026 MB
No install/uninstall in progress
Localstore Info - (0 apps)
Retrieving localstore information
I thought because of there is not software, status is not available. I tried to install software from ftp, it was failed too.
Router##service-module ism0/0 install url ftp://cisco:cisco@192.168.10.32/cisco/cue-vm-k9.sme.7.1.5.pkg
Proceed with installation? [no]: yes
%Error: Couldn't open ftp://*:*@192.168.10.32/cisco/cue-vm-k9.sme.7.1.5.pkg.install.sre
Execution of script cue-vm-k9.sme.7.1.5.pkg.install.sre failed, installation aborted
Router#debug ip ftp
*Jul 5 11:48:15.863: FTP: 220 Please visit https://filezilla-project.org/
*Jul 5 11:48:15.863: FTP: ---> USER cisco
*Jul 5 11:48:15.863: FTP: 331 Password required for cisco
*Jul 5 11:48:15.863: FTP: ---> ****
*Jul 5 11:48:15.867: FTP: 230 Logged on
*Jul 5 11:48:15.867: FTP: ---> TYPE I
*Jul 5 11:48:15.867: FTP: 200 Type set to I
*Jul 5 11:48:15.867: FTP: ---> PORT 192,168,10,1,202,196
*Jul 5 11:48:15.871: FTP: 200 Port command successful
*Jul 5 11:48:15.871: FTP: ---> RETR cisco/cue-vm-k9.sme.7.1.5.pkg.install.sre
*Jul 5 11:48:15.871: FTP: 550 File not found
*Jul 5 11:48:15.871: FTP: ---> QUIT
*Jul 5 11:48:15.871: FTP: 221 Goodbye
When I copy the same file from ftp, it succeds. So ftp directory is correct, file is there, but service-module cannot install.
What do you recommend?
Something wrong in your ftp access. The password when you login through console is same password which you use to access your router.
Please remember to rate useful posts
I have tried the same path and succeded to copy a file from ftp in the same router. I don't believe that there is a problem with ftp path.
I have tried router's username and password too but failed.
