Set CFALL per script on CUCM 11.5?
alig.norbert
Level 4
Level 4
Hi there,
We are moving from CME to BE6K/CUCM.
On the CME we had a quick&dirty script to change over SSH the CFA number on a specific directory number and send a mail notification.
Can this somehow be achieved with the CUCM?
Any ideas?
Norbert
alig.norbert
Level 4
Level 4
TAC could help me.
Here the SQL query:
run sql update callforwarddynamic set cfadestination = 'YYYY' where fknumplan = (select numplan.pkid from numplan where dnorpattern= 'XXXX')
YYYY -> insert the call forward destination.
XXXX -> insert the DN you wish to change.
Norbert
Jaime Valencia
Probably, but you'd need to do all the programming to use AXL, do the change and then send the email.
There is nothing out of the box to do that.
java
if this helps, please rate
Sorry for my delay.
I'm not the programming guy ;-). Have you any recomandation who could develope this for my?
Norbert
alig.norbert
Level 4
Level 4
TAC could help me.
Here the SQL query:
Norbert
