Will the change in DNS in CUCM 9.x will affect the license ?
dineshshoba
Hi Cisco
I am using CUCM 9.x version and want to chagne the DNS ip.
While change the DNS IP i am receving the error
WARNING: To avoid license synchronization failures, delete the
         product instance from the Enterprise License Manager
         managing this server's licenses before changing network
         settings.You will have to re-add the product instance
         after the network settings have been changed.
Is that necessary to remove and the add the cucm product from ELM to avoid this issue.
Or 9.x will not have any impact and we can proceed changing the DNS without remove/add the product instance from ELM?
Rajan
Hi Dinesh,
You just need to remove and add the product instance back in ELM and do a sync.
https://amyengineer.com/tag/cucm-dns-ip-address-changes/
Rajan
Pls rate all useful posts by clicking the star below
Rajan
Hi Dinesh,
Rajan
Thanks Rajan. It worked.
