Setting up SIP on a Cisco 7960
ekm170286
I have had now tried for some time to get some Cisco 7960 to work.
So far i have managed to get them to find and load files from the Tftp, although it doesn't seem like they can find the SIP"MAC-adress".cnf and load this.
Also the phones write up some error messages in the status when i look on the phones, after they have booted.
The files look like this:
SIPDefault.cnf
image_version: P0S3-8-12-00
# Extension to dial for voicemail
messages_uri: “999”
# Proxy Server
proxy1_address: “10.1.1.173”
proxy2_address: “”
proxy3_address: “”
proxy4_address: “”
proxy5_address: “”
proxy6_address: “”
proxy1_port: 5060
proxy2_port: 5060
proxy3_port: 5060
proxy4_port: 5060
proxy5_port: 5060
proxy6_port: 5060
proxy_register: 1
timer_register_expires: 600
preferred_codec: g711ulaw
tos_media: 5
dtmf_inband: 1
dtmf_outofband: avt
dtmf_db_level: 3
timer_t1: 500
timer_t2: 4000
sip_retx: 10
sip_invite_retx: 6
timer_invite_expires: 180
dial_template: dialplan
tftp_cfg_dir: “”
sntp_server: “”
sntp_mode: directedbroadcast
time_zone: EST
dst_offset: 1
dst_start_month: April
dst_start_day: “”
dst_start_day_of_week: Sun
dst_start_week_of_month: 1
dst_start_time: 02
dst_stop_month: Oct
dst_stop_day: “”
dst_stop_day_of_week: Sunday
dst_stop_week_of_month: 8
dst_stop_time: 2
dst_auto_adjust: 1
time_format_24hr: 1
dnd_control: 0
callerid_blocking: 0
anonymous_call_block: 0
dtmf_avt_payload: 101
sync: 1
proxy_backup: “10.1.1.173”
proxy_backup_port: 5060
proxy_emergency: “10.1.1.173”
proxy_emergency_port: 5060
enable_vad: 0
nat_enable: 0
nat_address: “”
voip_control_port: 5060
start_media_port: 16384
end_media_port: 32766
nat_received_processing: 0
outbound_proxy: “10.1.1.173”
outbound_proxy_port: 5060
cnf_join_enable : 1
semi_attended_transfer: 1
telnet_level: 1
services_url: “”
directory_url: “”
logo_url: “”
http_proxy_addr: “”
http_proxy_port: 80
dyn_dns_addr_1: “”
dyn_dns_addr_2: “”
dyn_tftp_addr: “”
remote_party_id: 0
call_hold_ringback: 0
stutter_msg_waiting: 0
call_stats: 0
SIP"MAC-Adress".cnf
phone_label: “IBBE”
line1_name: “201”
line1_shortname: “201”
line1_displayname: “201”
line1_authname: “201”
line1_password: “123456abc”
xmlDefault.cnf.xml
<Default>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
<mgcpPorts>
<listen>2427</listen>
<keepAlive>2428</keepAlive>
</mgcpPorts>
</ports>
<processNodeName></processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
<loadInformation8 model="IP Phone 7960">P0S3-8-12-00</loadInformation8>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesURL></messagesURL>
<servicesURL></servicesURL>
</Default
OS79XX.TXT
P0S3-8-12-00
And the errors on the phones are:
E600 REG send failure:
REGISTER
W350 invalid proxy_backup
W351 invalid proxy_emergency
W310 6 Error(s) Parsing:
SIPDefault.cnf
W220 TFTP Error: Not found IP
SIP"MAC-adress".cnf
W250 TFTP Error: Not found
dialplan.xml
I use pumpkin Tftp and i have also noticed that when looking for the SIP"MAC-adress".cnf it requests the file with some wierd signs in front of the file name like ||SIP"MAC-adress".cnf
anyone up for helping out?
asafayan
Level 4
Level 4
I have a very similar issue.  I have a CME router configured as follows:
voice register global
mode cme
source-address 192.168.70.237 port 5060
max-dn 2
max-pool 2
load 7960-7940 P0S3-07-5-00
authenticate register
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0001675596328227
voice register dn  1
number 73860
name BR2 Phone 1
voice register template  1
dialplan 1
softkeys connected  Endcall Hold Trnsfer
voice register dialplan  1
type 7940-7960-others
pattern 1 5....
voice register pool  1
id mac 000A.41F9.790E
type 7960
number 1 dn 1
template 1
dtmf-relay sip-notify
username 73860 password cisco
codec g711ulaw
My phone connects to CME but doesn't register.  I see a little X next to the phone icon on the phone display and my STATUS log on the phone reads:
REGISTER
W310 12 Error(s) Parsing:
SIPDefault.cnf
W320 5 Errors(s) Parsing:
SIP000A41F9790E.cnf
