01-02-2018 07:51 PM - edited 03-17-2019 11:52 AM
I erased a Cisco 7940 completely and it is currently running the universal application loader. I would like use TFTP to get the SIP firmware, which I have a copy of, onto the phone. However, when I press the settings button on the phone to try and change the phone's network settings to work with my TFTP/DHCP server, nothing happens. I have tried the lock/unlock sequence, which did nothing and have tried to erase it again several times. Does anyone know how to fix this, or does anyone know the default network settings inputted into the phone, so that I can make my TFTP/DHCP server match those settings.
Thanks in advance for any help :)
01-02-2018 11:26 PM
Hi josephninio,
You need to use a DHCP server which will provide network settings with option 150 to phone.
You can install tftpd32 (free) in your PC which will work as both dhcp and tftp server (if firmwares files are in your PC). In the DHCP settings set option 150 with tftp server address where firmware files are located.
PM
Please rate all helpful posts.
01-02-2018 11:41 PM
Does the phone have option 150 set in it by default and do I need to set a specific IP address for the phone and/or the TFTP server? Also, do you know what may be causing the setting button not to work?
Thank you in advance for your help
01-03-2018 03:05 PM
01-03-2018 03:23 PM - edited 01-03-2018 03:31 PM
Thanks for the reply.
Are there any instructions on how to properly format the XML file?
Also, is the phone looking for the TFTP server at a specific IP address?
I am not familiar with how to use the DHCP server to tell the phone the IP of the TFTP server. How do I do this?
Your help is very much appreciated. :)
01-03-2018 04:04 PM
