Setup seperate POTS FXO inbound/outbound for IP Phone
dan hale
Level 3
Level 3
Hi All, I have an exciting CME on a 2921 router. I want to have a separate POTS line that will come into an FXO port and then the final destination will be a 7965 IP phone. I have setup a separate COR so that this phone will not be able to make outbound calls on the other existing FXO ports and the inbound FXO should only come in on the 7965.
Does this config look correct? Any better way of accomplishing this?
***Class of Restriction***
 dial-peer cor list Separate-phone
 member Separate-phone
***Voice Port POTS***
voice-port 0/0/0
 connection plar opx immediate 6000
 description POTS Line for seperate phone
 caller-id enable
***Dial Peer***
dial-peer voice 10 pots
 corlist outgoing Separate-phone
 description ** Forward all Digits **
 destination-pattern 8T
 port 0/0/0
 forward-digits all
***Users DN***
ephone-dn  11  dual-line
 number 6000
 corlist incoming Separate-phone
Vivek Batra
Your approach seems fine but from configuration, looks like you are using same port for incoming and outgoing call.
FYR;
https://supportforums.cisco.com/discussion/12738046/cme-3-analog-lines
- Vivek
