shut, no shut dspfarm profile trasncode
Adrián Moran
Hi all, I want to modify codecs in the dspfarm profile, after shutdown the profile and try t modify the codec removing one of them I got this: profile oper state is down in progress, please wait for some time and retry
I try to no shut the profile but got this: profile oper state is down in progress, please enable after some time
how much time take this to end the shutdown?
sh dspfarm profile 2
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description : AVMBJ_XCODE
Profile Service Mode : Non Secure
Is there somethign I can do to faster this?
Profile Admin State : DOWN
Profile Operation State : DOWN IN PROGRESS
Application : SCCP Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : DOWN_PENDING
Total Number of Resources Configured : 11
Total Number of Resources Available : 11
Total Number of Resources Out of Service : 0
Total Number of Resources Active : 0
Codec Configuration: num_of_codecs:7
Codec : g722-64, Maximum Packetization Period : 30
Codec : g729br8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
I need to removed and add codecs and then torn on this profile, any advice?
thanks
MSE Adrian M.
Do you have active calls stuck? Ideally when you shut dspfarm it will
forcefully drop calls using dsp. Check show sccp conn
It seems that you are hitting this CSCue41195. If it continue for long time
then you need to reboot.
**** Please remember to rate useful posts
The resources might still being used.
Or it could be a bug :/  - https://bst.cloudapps.cisco.com/bugsearch/bug/CSCue41195
Rolando A. Valenzuela.
