Simple IP phone question (avaya and cisco network)
Roger Richards
My IP Office Device or Call server is plugged in to a cisco 2950 <-- port is configure with access port vlan 20
I have vlan 20 voice
I have valn 10 data
All phone are plugged into a Avaya POE (All setting are correct)
My phones will only work if I trunk All ports, but according to design, I am suppose to only ,"untagPVIDonly" or all ports .
Is it cause I set the port for the call server as an access port ? And an access ports are only untagged traffic? If so, How do I not make it not an access port and still allow the phones to reach the call server on vlan 20.
I hope I don't sound tooo foolish.
Dennis Mink
Roger when you say:
My phones will only work if I trunk All ports,  (does that mean you have it working???)
but according to design, (what design?) I am suppose to only ,"untagPVIDonly" or all ports
check the following post, which has an example:
https://supportforums.cisco.com/thread/2179048
Please remember to rate useful posts, by clicking on the stars below.
