Showing results forĀ
Search instead forĀ
Did you mean:Ā
simple question enabling remote-party-id on a 3825 voice gateway
keeled
Can you change the remote-party-id from "no remote-party-id" to "remote-party-id" within the config on a 3825 during business hours or will this cause a bump in the phone services?
Recently, our caller id stopped coming through to our phones. After calling our phone provider we learned they are sending the caller id information through the Remote-Party-ID field while our voice gateway is set to no remote-party-id.
Thank you. :)
Brandon Buffin
You can make the change. This should cause no drop in service.
Brandon
Brandon Buffin
Brandon
Thank you. I made the change and it was transparent to end users. :)
