Simulate ITSP SIP TRunk provider
jaheshkhan
Level 5
Level 5
I want to simulate  ITSP SIP TRunk provider in my collaboration lab.
How to do that? can i do it with CUCM? if so how to do that?
if im doing it with CME router or CUBE router how to do that?
can any body guide for that
balaji.bandi
thank you for the link.
Is it mentioning about how to setup ITSP service provider? i couldnt find any thing about that in the video. how to do it ?
can i try the following link for it?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/12_5_1/cucm_b_security-guide-1251/cucm_b_security-guide-1251_chapter_010111.html
Basically Lab means, you simulating the environment in the LAB,
here is steps :
you setup your one of the gateway as SIP provider
another routers  one as clients to register as a customer
you control the call routing logic on SIP provider router between those customer routers
or you can have also another Gateway on the SIP provider side - for dummy call routing to that gateway and play IVR.
This way you can test it your call logic with routing.
BB
