Single Number for Voice and Fax
KRISHNA K V
We have deployed the single number for voice and fax solution using cisco tcl scripts.
voice gw-- cucm--right fax server-- exchange.
Tcl script is loaded in the voice gateway. Whenever a call arrives at the voice gateway from pstn the script is initiated and welcome prompt is played and exactly after 9 sec call is connected to the ip phone. If a fax tone is detectred the call is routed to the fax server which is integrated to exchange server also.
Is there any way to reduce the timer to 4 to 5 sec. Also for every call the welcome script will play. Is there any other solution apart from tcl script. I have attached the tcl script.
Krishna
Network Digger
Hello Krishna, please advise if you found a solution to the problem because I want to do the exact same thing. 9 seconds is just too much.
Thanks.
