Single Presence Server used by two companies
rmckerrall1
We currently share our CUCM and Unity Connection Cluster with another company. They are interested in adding Jabber to their environment. They run completely separate and inter-domain communication is not required, however, their domain is separate.
Is it possible to have two domains sharing a single Presence server?
CUCM 9.1
Presence 9.1
Jaime Valencia
Not with 9.x, you'd need to upgrade to 10.x+ in order to use multi-domain, and you won't have any kind of separation between them, if they know the JID of users in the other domain, they can add them.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime
