Cisco TFTP
Syed
Level 3
Level 3
Dear All,
I have a quick question.
Could someone clarify me that why do cisco use TFTP during phone registration? Why not FTP or SFTP?
Thank you in advance.
Syed
5 Replies 5
Robert Shaw
Level 3
Level 3
TFTP relies on UDP and therefore requires less overhead than FTP or SFTP.  It's a simple file transfer method that is standard for most devices that boot from a network connection.
Are you having any particular problems or was it just a question?
Hi Robert,
It is just a question. Thank you for your quick answer.
Could you elaborate on this, please? or share a reference link.
Check out the following sections in SRND:
Trivial File Transfer Protocol (TFTP)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/netstruc.html
Mohammed Khan
Latest firmware phones uses http as well.
Check below link
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200408-Retrieve-Phone-Configuration-File-from-T.html
That is correct, but it still uses the TFTP "service" for it. So, essentially the "TFTP service" on CUCM node handled both.
