Single Sign on User Options Pages on CUCM 9.1
guilhem.perez
Level 4
Level 4
After upgrading from 8.6 to 9.1 CUCM versions, SSO with open AM didn't work anymore for CCMUSER pages (I get the authentication page asking username and password).
Before upgrading to CUCM 9.1 it was working.
I noticed ccmuser web URL page changed from https://CUCM_IP/ccmuser to https://CUCM_IP/ucmuser
So I add a new URL in J2EE Agent Application: /ucmuser/WEB-INF/logon.jsp (same as /ccmuser/WEB-INF/logon.jsp).
It doesn't work.
Does somebody  try to configure CUCM 9 with open AM for SSO for User Option Pages?
I didn't find any information regarding OpenAM configuration change with CUCM 9 for Web user pages.
Thank you
Best regards
Rob Huffman
Hi Guilhem,
Just wondered about this bug;
CSCtz50363 - SSO not working after L2 and RU, throws login page when accessed
Description
Symptom:
SSO feature is not working after L2 or RU upgrade, throws login page when accessed
Conditions:
After  L2 / RU with SSO enabled.
after upgrade, when tried accessing sso enabled webapss, login form is presented.
Workaround:
SSO feature should be turned off before L2 or RU upgrade. And enable SSO feature after upgrade
Details
First Found in:                          (1)
9.0(0.98000.171)
Status:
Fixed
Last Modified:
Jan 02,2013
Fixed in:                          (9)
9.1(1.10000.11),9.0(1.98000.1),9.0(1.10000.37)
9.0(1.10000.3),9.0(1.10000.15),9.0(1.10000.10)
9.0(0.98000.52),1.0(0.98000.42),1.0(0.98000.16)
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
2 - severe
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
