SIP and SCCP Paging Group
furdog
I have a Valcom SIP Paging device connected via SIP. We need to:
be able to page phones inside the office only on Extension 500
be able to page on the Valcom SIP pager on Extension 501
be able to page on both the phones inside and the Valcom SIP paging device on 502
When I dial 500 in pages inside and works
When I dial 501 is rings busy
When I dial 502 is pages on both.
I have the following setup:
voice service voip
ip address trusted list
ipv4 64.xx.xx.xx
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 192.168.32.1 port 5060
max-dn 55
max-pool 15
hold-alert
tftp-path flash:
create profile sync 0035061647522308
voice register dn 11
number 501
name VIP10-Ch-1
no-reg
voice register dn 12
number 502
name VIP10-Ch-2
no-reg
voice register pool 1
id mac 00D0.5F00.FBE9
type P600
voice-class codec 1
username cisco password cisco
voice register pool 2
number 1 dn 11
number 2 dn 12
dtmf-relay rtp-nte
no call-waiting
codec g711ulaw
ephone-dn-template 1
hold-alert 60 originator
mwi-type both
ephone-template 15
service phone headsetwidebandenable 1
softkeys idle Redial Pickup Dnd Join ConfList RmLstC
softkeys seized Endcall Redial Pickup Cfwdall Callback
softkeys connected Hold Endcall Trnsfer Confrn Park ConfList Select RmLstC
button-layout 7931 2
speed-dial 1 502 label "Both-Page"
speed-dial 2 501 label "Out-Page"
speed-dial 3 500 label "In-Page"
ephone-dn 11
number 101 no-reg primary
label C0 - Line 01
name C0 - Line 01
trunk 111 monitor-port 0/1/0
ephone-dn 12
number 102 no-reg primary
label CO - Line 02
name CO - Line 02
trunk 112 monitor-port 0/1/1
ephone-dn 13
number 103 no-reg primary
label CO - Line 03
name CO - Line 03
trunk 113 monitor-port 0/1/2
ephone-dn 14
number 104 no-reg primary
label CO - Line 04
name CO - Line 04
trunk 114 monitor-port 0/1/3
ephone-dn 21
number 201 no-reg primary
label Ext 201
name Ext 201
ephone-dn 22
number 202 no-reg primary
label Ext 202
name Ext 202
ephone-dn 50
number 500 no-reg primary
description PAGING
name PAGING
paging ip 239.0.1.20 port 2000
ephone-dn 52
number 502 no-reg primary
description PAGING & VALCOM
name BOTH
paging ip 239.0.1.21 port 2000
paging group 50,51
ephone 21
mac-address xxxx.xxxx.xxxx
ephone-template 15
max-calls-per-button 2
paging-dn 50
type 7931
button 1:21 2m22 3m23 4m24
button 5m25 6m26 7m27 8m28
button 9m29 10m30 11m31 12m32
button 13:16 14:15 15:14 16:13
button 17:12 18:11
ephone 22
ephone-template 15
paging-dn 50
type 7931
button 1:22 2m21 3m23 4m24
button 17:12 18:11
0 Replies 0
