02-15-2011 04:56 AM - edited 03-16-2019 03:27 AM
Hi guys
I collect 218MB of traces about SIP
Enable SIP Keep Alive
02-15-2011 05:13 AM
What version of cucm did you pull the traces from?
What is the version of triple combo your using?
I have seen the latest version of triple combo have issues with cucm version 7 and before. The new version made some changes to allow cucm version 8.
If you can let me know the versions i can check into it
thanks
02-16-2011 04:29 AM
Hi Craig
Thank you for your reply.
I found the problem. The triplecombo read just files ccm*.txt. I was input the sdl*.txt
thanks again
